Hi All and greetings from Australia, I have a Formula233 fitted with one of the early 496 mag ho 425 hp with a bravo one X diesel stern drive, Last year after a 6 month lay up, I tried to fire up the beast, turned the ignition on, waited for the fuel to prime up, cranked her over but she would'nt burst into life, found the main fuel pump in the cool can housing was seized, replaced with new pump 861156A1, (tested before installation, worked fantastic) installed the pump, removed old fuel filter, filled new filter with premium fuel & installed, then attached aux outboard fuel tank with primer bulb and manually primed fuel system until primer bulb was solid, cranked motor over but it wouldn't fire up, removed flame arrestor on throttle body and got son to spray some fuel as I cranked motor over, she burst into life and ran as long as my son sprayed fuel, later on, I found that the new main fuel pump is now seizedI have a new pump on order but I am affraid that this one might do the same and these things arent cheap!! Is there anything else I should be looking for that might cause this? all the wiring is factory standard and never touched or altered, could the pressure regulator be the culprit? I am at a loss, is there any other test I shoukld perform before I kill another fuel pump? sorry for all the questions, am getting stressed cheers from down under, Frank
LinkBack URL
About LinkBacks
, I will just put it down to bad luck and hope like hell that the new one doesn't do the same!! I did measure the voltage at the pump and it was 12 volts, as was the primary pump,
