I have a question about the “Black Soot” on your transom after a day on the lake. The history of the boat is as follows:
- 2005 26ft Cobra Razor
- 496 HO
- The boat was a repo that I picked up at the end of last summer. It only had 51 hours on the motor which as you know is really low for a boat that was 5 years old.
- I only put about 10 hours on it last summer before I put it away to begin the winter project.
I noticed that the transom was really black after a day of running the boat. I know I can expect some soot on the transom, but this was A LOT! So after doing the research I installed the following on the 496HO:
- Dana Marine Products Exhaust (Fuel pressure is set at 46)
- Whipple Stage II Tune
I was not looking to gain all kinds of power I just wanted to lean it out a bit and get the motor to breath and run and good as possible. On a positive note it definitely made a noticeable change on the power and the boat definitely has a little more punch across the board. However, this did absolutely nothing to correct the soot. After just a few runs up and down the lake I still get the soot on the transom. I know that a little is ok but this is really excessive. I have to continuously clean it off before the kids climb in the boat or it ends up all over my interior.
I have taken it so Absolute Speed and Marine and everything checks out ok on the computer. I really have no idea what to do at this point.
- Have any of you had this problem?
- The boat had low hours for a 05 so if it sat for a few years would something have gone bad (Rings, etc.) (I don’t see how rings can go bad from sitting, but I am desperate here!)
- Should I add more vents so the motor gets more air? There seems to be a lot of Cobras that do not have this problem so I do not think this will really help but once again…. I am desperate!
Any advice or ideas will be great appreciated!
