620 cube chevy
Results 1 to 2 of 2
620 cube chevy
    May 2011
    sumner county TN
    Default 620 cube chevy
    OK I have a Dart tall deck that I am building and I have got to get some heads and tunnel ram for it and I have been told that the Dart pro2 380cc heads and tunnel ram is to big for a 620 with 10-2 compression pistons so my ? is what will work well in a TX-19 jet with a dom pump with a A/B hi-helix impeller I have two 800 holley 4150s cam is a 4-7 swap with 114 center line with high lift low duration custom grind from comp cams for jet boats with 600 plus cubes THANKS JD
    Official Test Driver BOOSTPOWER's Avatar
    WORLDWIDE visit BOOSTPOWER.COM
    Blog Entries
    2
    Default Heads
    Quote Originally Posted by badjet View Post
    Hell, I would say that that head is not to big in general, however the BB3 Brodix may be a better choice. Of course the RPM range of your engine will determine the head size as well. Do you have a Max RPM in mind? Why did they do a 114 cam? It would be helpful to have the cam specs for this question to be answered properly.
    Alexi
