Guage readings help
Ok, I have a stock 460 on my jet boat and was wondering what is a normal engine tempature and oil pressure reading should be on my guages......what should my range be....THANKS
Official Test Driver
Assuming all of the gauges match the senders usually water temp will be 125-145 most commonly in our reigon and oil temp usually ranging from 180-220. Is there an oil cooler and were is your sender mounted as this will matter. Thanks
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
