Hello Alexi or other helpers I have a twin engine offshore style boat with twin 454's they have 781 large oval port heads, junk stock flat top cast pistons so I think I'm in the 8ish to 1 ratio, nice size hydralic flat tappet cams, 750 edelbrock carbs... ok here's my question since i can only afford to run the garbage 87 octane regular fuel sold here in California what should I set my total timing advance to? I want my most performance but don't want to detonate with my weak cast piston strength, is 33 degrees good? more? less? thanks so much for your help
LinkBack URL
About LinkBacks
