Fuel pump question
Results 1 to 6 of 6
Fuel pump question
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Default Fuel pump question
    Hello,
    My question is what would you recommend I use for a fuel pump? Brand and also elect or mech? Been away from hot boats for a lot of years and it seems like the company names I knew to be good 25 years ago aren't even in business anymore.... HELP
    The engine is a 468ci, 12.5:1, Comp magnum 288AR cam, Weiand tunnel ram w/2 6109 750cfm carbs it has Merlin heads. It is in a V drive that I want to keep somewhere between 7000 and 7200rpm. The engine builder dyno'd this engine with a single 1050 at 733hp at a little under either 6700 or 6500rpm (I don't have the info right in front of me and I'm old and I think I forget things sometimes)
    Really appreciate any advice you can offer, thanks.
    David
    Orlando.FL
    Edelbrock has a good pump, I myself run both electric and mechanical.
    Official Test Driver BOOSTPOWER's Avatar
    WORLDWIDE visit BOOSTPOWER.COM
    Blog Entries
    2
    You can run both, however check out
    The new Waterman brushless electric pump. Same and 2012 NASCAR pump but low psi version for you.
    Aug 2011
    Wasilla, Alaska
    BOOSTPOWER, thanks for the info, I went to their website and they are sure proud of their pumps.
    Schiada 201, can I get some more details like, model numbers and how you set both pumps up? Would greatly appreciate it, Thanks
    David
    Senior Member Untamed 777's Avatar
    Sep 2010
    Central Oregon
    Aeromotive makes great electric pumps.
    Team Untamed 777 T/E
    Blog Entries
    2
    AEROMOTIVE is good too, just really depends on the overall use
