[For Sale] bigblock buckshot trade for pool
Results 1 to 2 of 2
    Senior Member cola's Avatar
    yucaipa, ca.
    Default bigblock buckshot trade for pool
    i want to trade this car for a pool or sell it asap so pleae make an offer
    may consider a boat trade also
    buckshot x3 mid engine
    this is a very high end car with the best of the best parts
    one of the best handling cars
    chassis is all 1 3/4" chromoly 095 wall and susp is all 1 3/4" chromoly 120 wall
    25" front travel with king race 3" triple bypasses and king coil overs (chrome a-arms)
    24" rear travel with king race 3" triple bypasses and king coil overs
    rear sway bar
    565 cu in. big block fuel injected monster built by aero engineering
    9.3 l. 565 cu in.
    4.6 bore and 4 1/4 stroke
    Afr ported heads
    10.1 compression pump gas 91
    forged je.pistons
    Hbeam rods
    Jessel rockers and push rods
    Cam 276 50 lift. 650 110°
    mefi 4 fuel injection with dominator 1000
    Built in rev limiter and heat sensor cut off
    10 qrt. Pan
    pwr radiator
    pwr trans cooler
    30 gallon fuel cell with sender
    2" hollow spindles
    gear one front hubs and brakes
    gear one 2.5 power steering rack (chrome)
    gear one rear 934 hubs and brakes
    934 race prep cv's
    934 300m axles
    custom 4" exhaust
    17" douglas beadlocks
    37" front mohawk tires
    38x16.50 extreme dominator #2 cut paddles
    5- eagle eye 6" oval h.i.d lights
    chrome light bar on electric actuator that folds down and adjusts on the fly
    b&m pro shifter
    cnc hanging pedals
    racer x carbon fiber head sets with ipodn in car and car to car race radios
    custom jet trim seats black and silver with custom stitching
    buckshot 3" padded 5 point harnesses
    billet side mirrors
    all stainless bradied lines
    custom fully enclosed sheet metal body with hood and dash,rear light wing that has a trunk and hindges up to access fuel cell,over head console
    all sheet metal was powder coated then custom painted, also lined with vinyl or a high heat dynamat lined
    this car is very clean and very well built with no expense spared.
    this car is not a typical x3 with an ls motor and powerglide. it has big power and a huge drivetrain to back it, no more clutch or transaxle to deal with
    $70000
    adam
    909-380-9073
ID:	106240   Click image for larger version.
ID:	106241   Click image for larger version.
ID:	106237   Click image for larger version.
ID:	106238   Click image for larger version.
    yucaipa, ca.
    *********sold*********
