[For Sale] 2006 Sand Works, Sand rail
    Senior Member Cobra 02's Avatar
    Montclair
    Default 2006 Sand Works, Sand rail
    2006 Sandworks Buggy with all the goodies.
    Buggy is as follows: ls 1 450 h.p. Mendola MD4S Trans.
    1) 4130 1-1/2 chromoly chassis
    2) 4130 1-1/2 chromoly HD a-arms and tie rods
    3) 7/8 HD spindles
    4) Boxed in Extreme HD trailing arms 934 mid board
    5) Howe 2.5 steering rack and control valve with shaft
    and all u-joints
    6) Heim and mis spacer kit
    7) Sway bar kit
    8) Mid board hub with 6 piston calipers
    9) Front disc 4 piston brakes
    10) Fox 3 tube bypass shocks front and back
    11) Fox coil carriers with springs
    12) Douglas 17x6 front bead lock rims
    13) Douglas 17x12 rear bead lock rims
    14) STU 33x17 blaster paddle tires
    15) STU 10.50x17 razor front tires
    16) Aluminum side panels, wing trunk, roof, full hood, floors and
    radiator scoop
    17) Race prepped 934 cvs, 300m axles boot and bolt kit
    18) 4 PRP seats with adj head rest and PRP padded seat belts
    19) CNC pedal assembly, CNC cutter brakes and CNC throttle cable
    20) Shift assembly 2D
    21) Ron Davis double pass radiator and overflow bottle
    22) 20 gal custom wedge fuel tank
    23) PCI car to car with 4 carbon fiber head sets
    24) 3 sets of tires sand, dirt and vw
    Serious inquires only please. $32000.00
    909-730-8997
ID:	131578   Click image for larger version.
ID:	131579   Click image for larger version.
ID:	131580   Click image for larger version.
ID:	131581   Click image for larger version.
    Montclair
    Ttt
    Montclair
    ttt
    Montclair
    Default Sold
    sold
