I suggest the "Troll Fury" kit above. Here's the link:
Optima Battery Optima Batteries Free Shipping! Best Service! Deep Cycle Batteries Yellow Blue Red Top Optimum Quite a value and mounting case as well. I don't know about you and your new boat, but my engine hatch is ONLY up to get chairs out for the beach or to do maintenance. So, I don't care about billet battery trays.
Next, throw away the Perko switch and use the ACR or similar AUTOMATIC battery isolator. You WILL forget to switch the Perko at one or two points in your boating times. OR, you will tell someone to switch it one way and they will (unknowingly) switch it to the wrong setting. The automatic electric switches are the only way to go. Key on - everything is ONE BIG BATTERY - so it all gets charged. Key off - just your two or three STEREO batteries are active and the starter batt is sequestered. Some switching relays are even smarter and don't need to be wired into the key switch. They ONLY activate ALL batts at 13.8V or higher....meaning, when the alternator is charging. When the engine stops, the voltage goes right to battery voltage which will be 12.8 or so for a freshly topped off (by the alt) battery. Being below the 13.8 threshold, the batts are isolated from the starter batt. Very smart, super easy, FAIL SAFE.
Keep in mind that $400 or $600 here or there to make it RIGHT - is going to last you for 5,6, maybe even 10 years before you have to change anything out. My blue Optimas were put in the boat in late 2005. So, coming into SEVEN YEARS LATER, it was worth-while to spend (then) $320 on two batteries. I would have spent twice that by now on flooded batteries. AGM (Absorbed Glass Matt) batteries (which are NOT GEL) are 300 TIMES more vibration-resistant than flooded batteries. Since everything is spiral-bound and tight - the lead plates can't break during - let's say - rough water in the afternoon. So, a bit of $ now, will keep you safe and playing your stereo for several years to come.
FANS - I also run the horizontal fans, as my amps are being a seat. In the Havasu heat, fans are your friend. I just wire them onto the remote amp trigger. If you want to be trick down the road....there are heat-switches. When temperatures reach the adjustable set-point on the switch.....it turns on whatever they are hooked to. So, it would save some battery power by only coming on when absolutely necessary. Trick stuff.
HOWEVER - you don't need a whole lot of batt power now, as those amps are not near what your amount of speakers require. That being said, they will be running HOT. The trick with boats in hot temps is to run MORE AMP THAN SPEAKER. For instance, each FOUR 6" or 6X9s should have ONE four-channel amp of 75-100 watts PER channel at 4 OHMs. This way, each amp is not stretched out to twice it's limits or more. They will run COOL and have plenty of reserve power. Same with the 12"s ONE classD amp that will run 1000watts RMS at TWO OHMS would be the trick. Everyone wants to run ONE OHM to the subs. This is maximum current through the amp and thus, the most HEAT. 2ohms runs significantly cooler than 1ohm. So when upgrading your amps, pick ones that will run the power levels you want at 4ohms for the highs and 2ohms for the lows.
