You're starting down that road of greek to me, but specs I have.
The subs I will likely use have a Qts of .30, and the website says to give them 2.0c/f @ 33hz.
http://www.reaudio.com/specs.html#sp_sx
Again, the only problem I think I'd have with the box loaded and ported down firing is size. I want this to be the base of my back seat, and if I make it too tall, the seat base will be too high off the floor. I want the people in the back to be somewhat encased in the boat, not sitting on top of it. This gives me roughly 13" from the floor to the top of the box.
The speaker mounting depth is 6.5", so with 3/4" MDF on the top, that's already 7-1/4" out of 13. I guess that would leave 5" for the forward facing port - maybe that would work - but it shrinks my available cu/ft area.
