Optima or Die Hard Platinum?
Results 1 to 10 of 10
    Default Optima or Die Hard Platinum?
    Have blue top now, looking at Platinum anyone have any experience? Platinum's made by same Co. that makes Odyssey (Enersys), plus 36 month warr and SEARS is everywhere.
    Not the same battery.
    Platinum group 34: 880 cc amps w/ 68 hours reserve at 20amps.
    Oddyssey (1500) group 34: 1500 cc amps w/ 135 hours reserve at 25 amps.
    Not saying that the Platinum is a bad battery, just not the same. You get what you pay for.
    Yes Odyssey or Kinetik batteries are the way to go. They also hold there charge better during the off season.
    waitin' on summer AZREDNECK's Avatar
    Lake Havasu, Az.
    i did a magic deck boat with four pdx amps, four pair of jl 7.7 components, and two 12w6v2's with two stinger/odyssey 2150's running one bat at a time it plays for about 5 hours each bat at full volume.
    Went with the Die Hard Platinum Battery, well worth the money.
    Just got two Blue Tops from Costco and there's a $25 rebate on 'em
    Senior Member purrfecttremor's Avatar
    CHINO CA.
    Bought a new 31m optma blue top and it has 1125 cc amps and 155 reserve hours. Cheaper than my last oddyssey and it lasted 4 years.
    Senior Member Disco's Avatar
    Inland Empire, So Cal
    I'm running the Sears Platinums, but the big ones. I have a modest (by these standards) stereo. I've had very good luck with them. I'm running 2 JBL 1000w amps and one 500w Kenwood. I can float for 3 hours running the stereo on one battery, and still start the boat. The 36 month warranty is not pro rated etiher, it's straight replacement. They're heavy mothers though.
    A parent’s only as good as their dumbest kid. If one wins a Nobel Prize but the other gets robbed by a hooker, you failed.
    Sep 2008
    I think you misread the specs. Although there may be some other differences, at least from a specs standpoint, I don't see any difference between the two.
    What got me curious (and how I found this thread to begin with) was that I found a press release by Enersys (the company that makes Odysseys) announcing a deal with Sears for their Platinum batteries. I didn't see anything regarding DieHard Gold, which is a totally different architecture.
    The DieHard Platinum specs are:
    Platinum group 34: 880 cc amps w/ 68 hours reserve at 20amps, 135 minutes reserve
    The Odyssey 1500 specs are:
    Odyssey group 78: 880 cc amps w/ 68 hours reserve at 20amps, 135 minutes reserve http://www.odysseyfactory.com/batterysearch.asp
    Don't know what the siggnificance in the group sizes are. When I called Sears, they said the specs are the same as the web site, but I noticed Sears reports about 4 lbs more weight than the Odyssey site (which could include shipping or some other variable).
    Quote Originally Posted by H2oSki2Fast View Post
    Steady Rollin
    Corona
    looks like you are right,
    Here is the press release from enersys.
    http://www.virtualjeepclub.com/showthread.php?t=35449
