Resin for sub boxes.
Results 1 to 9 of 9
    Default Resin for sub boxes.
    I have some new sub boxes going in that I have resined and glassed the hell out of on the outside but was wondering if I am supposed to do the inside as well. I had heard in that past I was not supposed to because the density of the mdf helps with the sound but I have also heard to do the inside as well.
    Thanks for any help.
    ive never glassed the inside of the boxes..if ur using mdf and you glassed the whole outside of the box its all good man
    El Cajon, CA.
    Quote Originally Posted by SexyTime396 View Post
    X2
    Thanks guys, I will give it a try with no resin. Just worried about moisture and the mdf.
    waitin' on summer AZREDNECK's Avatar
    Lake Havasu, Az.
    some times i resin both inside and out, but its not needed but its safe to.
    if its a sealed box dont worry bout it, just use poly fill. if its ported it makes a better sound when smooth. plus it makes for a longer lasting box.
    hope this helps.
    j.p.
    Wade & Denise Miss Venomous's Avatar
    Simi Valley, CA
    Do you have to resin the box? or is it just a precaution for moisture?
    El Cajon, CA.
    Quote Originally Posted by Miss Venomous View Post
    Solely for moisture resistance.
    Thanks for the info guys.
    Senior Member ClassicBoats's Avatar
    San Bernardino, Ca
    I sprayed my mdf with polyurithane spray on the inside.
