More Questions!!!!!!!!!!!!
Results 1 to 8 of 8
    Senior Member Wishful Thinking!'s Avatar
    Apr 2009
    Irmo S.C.
    Default More Questions!!!!!!!!!!!!
    If I have to get 2 amps, do I care how much power the head unit has?
    Apr 2009
    Irmo S.C.
    Poly-Planar or Boss any good?
    ....at the Speed of Sound SPL2K's Avatar
    LHC-AZ
    no
    no, and no.
    The HMFIC HWLaser23's Avatar
    fontana ca
    head unit power is nil when running amps. speaker wires run from amps and the signal is sent via rca's from the head unit to the amps. as for the brands of those amps or head units dont do it. get something reputable with ipod control. you can get a good alpine, kenwood, or panasonic for less than 200 in cali. or even on ebay for that matter.
    BLACK SMOKE DON'T MEAN ITS BROKE
    Senior Member Dan_Lorenze's Avatar
    Moorpark CA
    I'm thinking you might be best off taking your boat in and having a professional install a system for you. That doesn't mean you'll have to spend an arm and a leg, it just means that the job will be done right, the first time, using quality components.. You really want the system to be balanced and wired correctly. Any professional audio installer will give you options either to go big or to be on a budget.. Just my .02 good luck..
    Apr 2009
    Irmo S.C.
    MB or MTX any good?
    Quote Originally Posted by SPL2K View Post
    no
    no, and no.
    LOL. x2
    Quote Originally Posted by Wishful Thinking! View Post
    MB or MTX any good?
    Your better off stating what your budget is to get good opinions on equipment. Also, you may want to add what types of speakers your wanting to run as well.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
