On board battery charger?Power supply?
Results 1 to 14 of 14
    Sep 2008
    Spring Valley Lake Victorville Ca./Lake Havasu City Az.
    Default On board battery charger?Power supply?
    Is a charger and a power supply the same thing?I have a Honda EU1000I generator that I want to use in my boat to keep my 3 Optima battery system 1 house and two for stereo charged.I have a Kicker 1000 and a Kicker 650 running 3 sets of 6.5 comp. and two L7 subs,the batterys and stereo is all new but it only last about 3 to 4 hour.So what I want is something that can charge or supply power using the generator during the day but then be able to plug in at home at night and fully charge the batterys for the next day of use? I also dont know if I need a 2 or three bank...2 if I charge each stereo battery or three and charge the house battery too?I have done some reading and with the EU1000I I can only get a charger with 55amp max? Anyone with a setup like this that can help please let me know dont want to spend money twice or blow something up.Regards, Frank
    Senior Member Sig Ep Mock's Avatar
    I run one of these chargers
    http://www.pmariner.com/productFeatu...oductNum=41220
    Even though you only have two banks...you need the three bank charger for the three sets of leads that come off it. The charger is smart enough to recognize that two batteries are connected in parrallel and will adjust. I don't run a generator...haven't had to yet but I run one house and three stereo batt's. Just plug it in at night. The charger will also maintain the batteries during storage when plugged in.
    I've been running it for aalmost 3 years now with no problems.
    Hope that helps,
    Chris
    Insurance God millhouse961's Avatar
    Santa Ynez, CA
    Quote Originally Posted by Sig Ep Mock View Post
    Hope that helps,
    Chris
    If I'm only running 3 batteries, 2 in parallel and one by itself, can I get away with just the 2 bank charger? I.e. the pro sport 8 instead of 20?
    2003 Cobra 270 Razor
    Quote Originally Posted by millhouse961 View Post
    You might be able to but the Pro Sport eight is only going to give you a max of 8 amps to any one bank so that's only 4 amps to the two in parrallel...I have found the key to a long battery life and battery charger life has been good solid charging. The Pro Sport 20 can give 20 amps to any one battery or distribute it among your three. The Pro Sport 8 would be working pretty hard to up 3 batteries.
    In my opinion the Pro Sport 20 is really the starting point for a good on board charger maintainer and worth the extra money considering the costs of good batteries.
    Chris
    Santa Ynez, CA
    Chris
    hmm...good point. I have cheap batteries now but at some point they will wear out and I will upgrade. gonna have to think on this one
    Overton's has the 8 for $99 and the 20 for $189......That's less than one battery difference
    I run the 8 on my motorhome to keep the motor batteries charged and it works hard just keeping 2 batteries charged, it's get's pretty warm. I wish I hadn't cheaped out on it and just bought the larger one.
    Chris
    Santa Ynez, CA
    Chris
    Isn't there an in between option...like a 12 I think?
    Sep 2008
    My friend has a Guest ProCharger 2631a it is a 30amp 3 bank in his Hallett for two years now and he said he has had no problem with it and he also runs a Honda 1000,I like that it is 10amp per battery so I think I might get it does anyone know a place that sells them for a good deal?Frank
    Member gordon's Avatar
    Are these just chargers when at your house. How do you keep batteries from dying on water is generator the best idea
    I think it's a 15.
    We ran the stereo pretty hard last weekend for probably 6 hours and the batt's held up. 3 deep cycle marine batt's, plugged the boat in overnight and they where ready to go again the next morning.
    A lot has to do with the type of amp you are running....I run 4 Alpine PDX amps which are digital amps and use less energy. The older style amps can draw a lot more juice and kill batteries faster. I still think the Pro 20 is a minimum for an on board charger. If you're going to run an onboard geny then get the largest charger you can....30 amp would work really well.
    Just my $.02,
    Chris
    Santa Ynez, CA
    I think it's a 15.
    Just my $.02,
    Chris
    Took your advice and got the prosport 20. Came in the mail yesterday, will be hooking it up tonight!
  13. #12
    Cool. Hope it works out or you'll really be pissed at me Seriously you should be happy with it and get a longer life from you batteries.
    Chris
  14. #13
    Santa Ynez, CA
    Chris
    I installed it last night and love it. So much easier now to just plug the boat in and be done with it
  15. #14
    JryLineman goat's Avatar
    Peoria
    Quote Originally Posted by DaBank View Post
    Almost bought the same one but went with a Pro charging System,two bank, 30 amp. They are suppose to fully charge my Odysseys in about an hour.
    Was an option for the boat, but blew it off.
