Question...
Page 1 of 2 12 LastLast
Results 1 to 14 of 20
Question...
    Senior Member SHOCKtheMONKEY's Avatar
    Yucaipa
    Default Question...
    I've got a basic stereo with four 6x9's. I've added an amp and subwoofers.... What's the best way to get rid of the low bass going to the 6x9's?
    THANKS!!!
    detachable member 3queens's Avatar
    Ranchocuca..BHC, Az
    get a four channel amp
    Yucaipa
    I'd love to spend a few thousand on a new system, but that's not in the cards right now... Is there something I can put on the 6x9's to stop the low bass or perhaps some kind of crossover?
    Ranchocuca..BHC, Az
    you can find a 4chanel for a few hundred no need to spend thousands
    273.36 Miles from Havasu
    You can run a passive crossover in line with each 6x9...they can block low fequencies.
    However, if you turn up the gains on the sub and turn down the bass boost on the head unit, the 6x9's will distort less, but you'll have the same amount of audible bass.
    Perhaps I'm gay...
    Yucaipa
    Quote Originally Posted by Havasu Hangin' View Post
    Where do you find those at?
    mach26 300's dschifan's Avatar
    So Cal/Willow Valley
    exactly what i did
    Professional Lurker BOBALOO's Avatar
    southern ca.
    Quote Originally Posted by SHOCKtheMONKEY View Post
    Almost any stereo shop. They should be cheap, just wire one inline to each 6x9.
    What are some details of your system? Are you running the 6x9's on the head unit and the subs on the amp?
    What kind of amp 2ch, 4ch amp?
    Subs, in boxes or free air?
    Quote Originally Posted by H20 Toie View Post
    Why would anyone ever bother posting while drunk?
    Senior Member W.O.T's Avatar
    Campo Ca
    get capacitors for each speaker. they are cheap and block low frequencys. i used to use them on mine did the trick.
    Senior Member Warlock1's Avatar
    Surprise, AZ
    I second the cap trick. Pick them up for a couple of bucks, solder across the terminals and your done. They act as a filter. Look at the specs on your speakers and calculate what size caps you need and head to Radio Shack.
    Yucaipa
    Quote Originally Posted by BOBALOO View Post
    Yep, 6x9's off of head unit, subs off two channel amp in a box....
  13. #12
    Yucaipa
    Now that you mention it, I put caps on my subs back in the eighties to block out the higher frequencies.... big ones about the size of a half roll of quarters....
  14. #13
    El Cajon, CA.
    Caps block bass so that wouldn't have worked. Coils block higher frequencies.
    If your 6 X 9's are 4 ohm get a 100 micro farad non-polorized cap for each 6 X 9 and you'll stop the bass going to them. Put the cap in series with the positive speaker lead.
    Changing the bass amp's gain, adjusting the bass level in the deck, any other adjustment is just going to be a lame not the right way to do it kind of answer, IMO.
  15. #14
    not ****** little squirt's Avatar
    Waikiki, HI
    yo peep these
    http://www.crutchfield.com/App/Produ...S&i=127BB150A2
    you can do a search for bass blockers probably on any stereo web site. good luck.
    not banned
