AKA Blownjet 468
Punch 45HD wiring info?
anybody out there that can tell me the speaker wiring sequence on a punch 45HD? I don't have the plug that goes w/ the amp, but I could
make one if I could find out what pin corisponds with each function.
all I do know is it's a 6 pin plug, with only 5 pins used.
....at the Speed of Sound
AKA Blownjet 468
don't want to buy it, when I can make it ! just need to know what wire goes where! color and pin location!
Spiral out
Pin out for Punch 45/75/150. (not sure if same for HD model....but likely)
orange - left positive
black - left neg
yellow - right pos
brown - right neg
red - + voltage to turn on antenna
to bridge mono
orange to brown (can only load to 2ohm......no less!)
Spiral out
I'll have to see if I can easily see the plug for wire position tomorrow.........
AKA Blownjet 468
thanks guys, looked at that e-bay seller ad, and kinda think I can figure it
out, but if you can look and double check, i'd sure appreciate it!
what I can sort of figure is;
looking at amp, six pin plug, top row (3 top)
1st pin--not used/ 2nd pin--yellow/ 3rd pin--orange
bottom row (latch hook underneath)
4th pin--red/ 5th pin--black/6th pin--brown
I know the plug will be mirror image, does this sound correct?
P.S.--Thanks for taking the time to look
Spiral out
I don't know if you'll get it but the plug looks like this
_ '''''' _
B BR R
O Y
"""_ """
The "_" is the flat on the plug facing away from center.
Do you get it?
AKA Blownjet 468
yeah, I think that's the same as what I put above your post, except
upside down
You may not post new threads You may not post replies You may not post attachments You may not edit your posts Forum Rules
