hello. I'm new to the thread and somewhat new to boat wiring. in attempt to clean up and simplify my pilot house trawler's wiring, I ended in failure. I have the classic Perko switch, Off, 1, both and 2, with it wired up the way in the attached link, I have power to all 12v systems coming from the fuses block and the positive bank while in the "Off" position. Switching it to any other position doesn't change a thing.
wiring diagram
http://danimal.myphotoalbum.com/view...wiring_diagram
after messing around with different combinations I found that if I moved the positive wires coming from the fuse bank and the positive bank to the common terminal on the switch that it all turned off when I moved the switch to the off position. my goal is to in the
"Off" position have no power at all(except for the hard wired bilge on a float).
"#1" position only be able to start my boat's engine w/ no power to 12v accessories.
"#2" position to have power to all 12v accessories and no power to engine.
how can I do this? thanx daniel
