Hooking up 2nd battery
Results 1 to 9 of 9
    BANDAID DUDE! HiMark Racing's Avatar
    Sep 2010
    Lincoln, California, United States
    Default Hooking up 2nd battery
    So I broke down and bought a 2000 watt amp..I want to put in a second battery with Perco switch..Can someone show me a scamatic of how I should do it please..Also need to run approx. 12' of red wire..Is 4g big enough to run 4- 6 1/4 and a 10" woofer?? As far as a ground, guessing I need to run back to block..?? Yes??
    Thanks in advance,
    -g
    Lost Wages, NV
    So you currently have one battery that powers everything and you want to add a second battery? Do you want this separate battery to be able to combine with the original and start/run the boat, or only run the stereo off it, leaving the original battery to run the boat? If you do it that way, you will always have a battery to get home on.
    Keith-
    Sep 2010
    Hmmm, good question..It probably be easier for me to just have one battery isolated to just the stereo.
    Aug 2010
    Sep 2010
    Quote Originally Posted by ka0tyk View Post
    Must have been good!!
    Aug 2010
    Quote Originally Posted by HiMark Racing View Post
    heh whoops.
    http://continuouswave.com/whaler/ref...ine441x370.gif
    copy/paste that into yer browser. its a diagram. also when u buy a perko theres instructions on how to wire it with 2 batteries 1 engine, 2 and 2, etc...
    Sep 2010
    oops, that cut/paste didn't work either...you try.
    I think I found it though..thanks again.
    Senior Member yhammack's Avatar
    Folsom, CA
    Here is a simple Diagram:
    I have a big stereo in mine with the same setup (Not a wacker for a motor though. lol) I run off 1 battery for everything, starting, lights, stereo, etc. So it's always on battery 1, battery 2 is backup but it will still run all the lights and stereo. So far this summer I haven't even had to switch to battery 2 yet.
    4 awg at 12' for 2000 watts is as small as you'd want to go. I run 2 amps, 1000watts (probably more like 1200) for the sub and 600watts for the highs. I ran 1 0 awg wire from the common on the perko switch to the fuse block, the 2 4 awg wires (about 15' each) to the amps. Then for the grounds I ran 2 4awg wires back to the battery and each of those go into a terminal on the battery big enough for them. The grounds are tied together so it doesn't matter which battery. I didn't use the block because unlike a car, the entire boat isn't grounded through a chassis. I get zero engine noise through the speakers this way.
    Hopefully that helps.
    Lost Wages, NV
    Keith-
