Hey guys need some help here, Ill try and keep it as short as possible, bought a 1971 Sleek Craft and the original owner built a system that has 12" sub and 2 6x9's, plus 1000watt amp powering the sub and 6x9's. I had to remove the sub enclosure for some fiberglass boat repairs and seems once I wired the speakers back together Ive had issues. I thought I didnt connect the sub and mids up correct since they were playen at one time then on a weekend test run recently all sound was gone, but the head unit had power. I had a good Sony head unit I replaced the old with in the boat, Re wired it all back up, yellow to live 12v, red, ground, and blue amp remote all hooked up, with the radio on I can find a station that comes in clear since I have no antenna, the sub works, 6x9 work on radio, sounds fine to me. But when I try to play a cd in the new installed unit, it kills the amp and green power light on the amp? why would switchen to CD or AUX kill the amp, the green power light on the amp slowly dims withen 7 seconds, then amp is off, head unit still on and playing CD, just no sounds coming out, then if I switch back to radio, the music and amp and green light will come back. Ive never heard music when a CD is playing however, but when I switch to play CD, I can see it playing on the unit, time is counting, I can hear the CD spinning? but withen seconds it amp is dead and no sounds? Here some quick pics of the system, they are mounted down where the gas pedal is, but facing out.![]()
LinkBack URL
About LinkBacks
switch the
