engine loads up in reverse with rebuilt pump
Results 1 to 7 of 7
    Member HaulsBalls's Avatar
    Mar 2011
    Corona, CA
    Default engine loads up in reverse with rebuilt pump
    I recently rebuilt my 12JC and had it out for the first time the other day. I noticed that when I reverse the bucket covering the nozzle my engine seems to load up noticeably and drop a 2-300 rpm, is this normal? Is just having a fresh impellor and wear ring build that pressure/load when the nozzle is closed off and redirecting flow?
    World's #1 Jet Drive BerkeleyJet's Avatar
    This isn't something we've seen before. It's not normal but dropping the reverse bucket just redirects the water, it shouldn't have any effect on RPM.
    "Start Berkeley Original, Stay Berkeley Original!"
    Senior Member cruzer's Avatar
    Chandler, Az
    Shifter/throttle on the same handle or Forward/Reverse handle and foot throttle?
    Cruzer
    21 Eliminator Daytona. Blown 540
    Hoodys and swim trunks Elkidminoltu's Avatar
    Waterford, MI
    Quote Originally Posted by cruzer View Post
    I'm thinking along the same lines. Check your adjustements on your cables at the ends, specifically the throttle cable. In Neutral position, your throttle cable may be pushing/pulling on the carb linkage and keeping your idle up, then when you go in reverse it drops it down onto the idle adjustment pin on the carb,thus lowering RPM. Unhook the throttle cable, fire the motor, and see where it idles and if it changes when you fwd-rvrse the bucket.
    It should be adjusted so you are able to throttle the boat in reverse some.
    Jul 2009
    That would do it!!
    Senior Member nick's Avatar
    La Habra & Water Wheel Resort
    He has a foot throttle and a fwd/reverse lever, they are totally seperate and not related on his boat.
    Any other ideas?
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    I had the same problem on a Hamilton Jet unit. Doing emergency stops, the bearing damaged the bearing cap, the shaft started moving forward and backwards inside the pump, pushing the impellers against the stators and wear rings when reversing. The resulting friction resulted in RPM drop when I reversed.
    Wikus
