Restore Color & Shine to Boat Finish - Repair Gelcoat from Dullness & Oxidation
How do you restore boat fiberglass that is severely oxidized without wetsanding? With Bio-Kleen Restore & Shine Xtra Cut. Restore paint, remove oxidation, remove swirl marks, restore color and repair damaged fiberglass gel coat in one step. This product is used by professionals at marinas and marine detailing businesses but is also easy enough to use right at home.
This video focuses on the demonstration process to restore color and shine back to a faded and oxidized colored fiberglass boat. This demonstration is completed using the Bio-Kleen Restore & Shine Xtra Cut. This compound allows you to easily restore the color and shine back to your fiberglass in one easy step, not several as experienced with other compounds on the market. You can see that in addition to restoring the color the Bio-Kleen Restore & Shine Xtra Cut polishes and seals the fiberglass at the same time, adding remarkable shine and protection.
