1995 big block 454 Mercruiser
Results 1 to 2 of 2
    Nov 2013
    Default 1995 big block 454 Mercruiser
    I have big block mercruiser 454 carberated with an alpha 3 outdrive (dual prop) about 300hp in a 21' celebrity. I am wondering at this point what is my best option for more hp. It has about 450 hours on it. Should I pull it and rebuild, drop something bigger in it, or add parts.
    Feb 2014
    The real question is how much more horsepower. A little is cheap and easy, but the cost rises exponentially as things need to upgraded to handle more and more power.
