Gaffrig Blowout!!
Results 1 to 7 of 7
Gaffrig Blowout!!
    One Free Call Does it All CP Performance's Avatar
    Rohnert Park, CA
    Exclamation Gaffrig Blowout!!
    Okay folks, here is your opportunity to save big on some overstocked Gaffrig gauges. You will not find prices like this anywhere and there are only a limited supply so don't hesitate!
    Please do not ask for a gauge that is not listed because I do not have it!! Any extra gauges that you might need can be replaced with our Autometer, Livorsi Marine, or Hardin Marine gauge lines only.
    Got senders? All senders all sold seperately so let me know if you need them when ordering a gauge off the blowout list.
    Let the games begin
    All orders can be taken by phone, email or private message only and is based on a first come first serve according to the date and time of a request.
    Rohnert Park, CA
    Qty and Sell Price in RED
    Part# - Qty - List $ - Sell $ - Description
    4004 3 109.76 $41.00 3-3/8" Mech.Dry Speedo 80MPH, BLK
    4020 3 373.17 $138.00 GPS Digl. Speedo Head, BLK
    4024 1 373.17 $138.00 GPS Analog 120MPH Speedo, BLK
    4026 1 170.73 $63.00 3-3/8" Mech. 100MPH Speedo KT, BLK
    4028 1 170.73 $63.00 3-3/8" Mech. 120MPH Speedo KT, BLK
    4038 4 170.73 $63.00 3-3/8" Mech. 60MPH Dry Speedo, BLK
    4040 4 170.73 $63.00 3-3/8" Mech. 80MPH Speedo KT, BLK
    4250 4 165.85 $62.00 3-3/8" Elec. 0-10000RPM Tach, BLK
    4252 12 165.85 $62.00 3-3/8" Elec. 0-6000RPM Tach, BLK
    4254 1 165.85 $62.00 3-3/8" Elec. 0-8000RPM Tach, BLK
    4502 40 109.76 $41.00 3-3/8" Speedo White
    4508 1 109.76 $41.00 3-3/8" MechDrySpeedo 120MPH, WHT
    4525 3 819.25 $303.00 GPS WHT Analog KIT
    4526 7 170.73 $63.00 3-3/8" Mech. 100MPH Speedo KT, WHT
    4528 3 170.73 $63.00 3-3/8" Mech. 120MPH Speedo KT, WHT
    4538 3 109.76 $41.00 3-3/8" Mech Dry Speedo KIT, WHT
    4540 3 170.73 $63.00 3-3/8" Mech. 80MPH Speedo KT, WHT
    4750 6 165.85 $62.00 3-3/8" Elec. 0-10000RPM Tach, WHT
    4760 6 195.12 $72.00 8K Tach/Hour I/O, WHT
    5001 1 217.07 $81.00 DGTL Sound Head W/Alarm, BLK
    5002 1 41.34 $16.00 Electric Fuel Level, BLK
    5004 2 46.95 $18.00 2" Elec. Fuel Press 0-100PSI, BLK
    5006 3 46.95 $18.00 2" Elec. Fuel Press 0-15PSI, BLK
    5008 3 46.95 $18.00 2" Elec. Fuel Press 0-60PSI, BLK
    5020 5 107.93 $27.00 2" Elec. Oil Temp., BLK
    5024 1 72.00 $36.00 Elec. Pyrometer 0-1600, BLK
    5026 16 46.95 $18.00 2" Elec. Trim Meter Merc, BLK
    5032 9 41.34 $16.00 2" Elec. Voltemeter, BLK 8-16V
    5040 10 41.34 $16.00 2" Elec. Water Temp. BLK 100-240F
    5050 2 85.37 $32.00 2" Elec. Fuel Press. BLK 0-60PSI
    5504 5 46.95 $18.00 2" Elec. Fuel Press. WHT 0-100PSI
    5508 4 46.95 $18.00 2" Elec. Fuel Press WHT 0-60PSI
    5514 2 85.37 $32.00 2" Elec. Oil Press. WHT 0-100PSI
    5518 1 85.37 $32.00 2" Elec. Oil Press. WHT 80PSI
    5526 3 46.95 $18.00 2" Elec. Trim Meter Merc. WHT
    5530 1 [B]20.00[B] $18.00
    2" trans/temp Elec white
    5532 8 41.34 $16.00 2" Elec. Voltmeter WHT 8-16V
    5542 3 41.34 $16.00 2" Elec. Water Temp. WHT 100-280F
    5550 2 85.37 $32.00 2" Elec. Fuel Press. WHT 60PSI
    5552 2 85.37 $32.00 2" Elec. Trim Meter Merc. WHT
    6018 1 66.34 $25.00 2" Mech. Vac. 0-30HG/0-30PSI BLK
    6516 1 66.34 $25.00 WHT Vacuum Gauge
    9100 1 48.78 $18.00 Fuel Press. Sender 0-100PSI
    9110 3 19.51 $8.00 Oil Temperature Sender 1/2"
    9124 1 19.51 $8.00 Water Temp. Sender 1/4"
    9132 8 19.51 $8.00 High Water Temp. Sender 1/4"
    9134 10 19.51 $8.00 High Water Temp. Sender 1/8"
    9136 4 19.51 $8.00 High Water Temp. Sender 1/8:"
    9138 5 109.76 $41.00 Fuel Level Gas 0-12" Tank
    9140 6 112.2 $42.00 Fuel Level Gas 0-24" Tank
    9251 16 436.59 $162.00 GPS Receiver, WHT
    9256 1 15.25 $6.00 Brass Comp. Fittings
    9300 30 9.15 $4.00 Toggle Switch Mom. On/Off
    9400 30 8.54 $4.00 Rubber Boot BLK for Toggle Switch
    9401 24 8.54 $4.00 Rubber Boot WHT for Toggle Switch
    13005 1 75.52 $32.00 2-5/8" Voltmeter, WHT
    9000-05 2 346.35 $128.00 Hydro Cool Powercoated, BLK
    9000-08 1 346.35 $128.00 Hydro Cool Powercoat. Polish Alum.
    Last edited by CP Performance; 11-03-2008 at 03:13 PM. Reason: Updated Inv. and pricing
    Rohnert Park, CA
    They are going fast!!
    Rohnert Park, CA
    Rohnert Park, CA
    The list has been updated
    Rohnert Park, CA
    Default Update!
    We have just updated the list of Gaffrig gauges we are blowing out and reduced the price even more! These gauges are can't get and cheaper. They need to go, quantities are limited, get yours now!
    CP Performance
    www.cpperformance.com
    One Free Call Gives You Access To Over 500,000 + Items!
    800-225-9871
    Rohnert Park, CA
    Still have some of these gauges available. Nows the time, don't wait!!
    CP Performance
    800-225-9871
