Yes the cam did break. We just didn't know why until now. Our theory on why the cam broke is that the #8 exhaust valve broke, which caused the spring to relax against the rocker, which jammed the lifter into the cam and bound it up, causing it to break. As to why the exhaust valve broke...by looking at things I couldn't figure out why it had. Could've been a bad valve from the start.
Another possibility is that the crank key on the timing gear may have sheared, but he didn't have the timing cover off yet when I went down there to look at things.
In regards to the "eyebrows" on the 1, 3 and 5 pistons...I got these heads off of eBay and don't know if they were ever on the same motor or not. We're thinking that at some point the head was milled down for whatever reason. He's gonna CC the heads to find out. If that's the case we'll have to go with different pistons...which would suck because then I'd be left with 7 perfectly good pistons that I can't really do much with. Or...not
If everything goes as planned I'm hoping to have her back on the water by then end of
Febuary. As far as upgrades, I'm just wanting to restore the motor back to the way it ran before it blew, but we all know how that goes.
