Originally Posted by
Jetaholic
Anytime Byron. Here is a "light list" of sorts for ya -
Red markers are even numbers
Green markers are odd numbers
When the red markers are to your left and the green markers are to your right, you're heading northwest away from Stockton
When the green markers are to your right and the red markers are to your left, you're heading southeast towards Stockton
Heading out of Windmill Cove and going northwest -
Channel marker 33 is Ski Beach and Fourteen Mile Slough, which will take you to Garlic Brothers. To get to Garlic Brothers, you follow the levee on your left. When you get to the end of that, you go right and follow that around to Garlic Brothers
Channel marker 24 - Turner Cut (back side of Lost Isle). This is where you turn to go towards Tiki Lagun and also the start of the route to Disco Bay/Orwood
Channel Marker 11 - Little Connection Slough. Turning here and going straight up will take you to Herman & Helens and Tower Park
Channel Marker 49 - Moukeloumne River (The "Moke"). Turning here will take you right to Pirate's Lair, Willow Berm, Riverboat, Lighthouse. A little further up is B&W, but your rollbar may not clear the Highway 12 bridge at high tide (8' vertical clearance at high water tide, 11' at low water tide)
Passing B&W and staying with the levee on your right will also take you to Tower Park
Passing B&W and continuing with the levee on your left will take you to Guisti's
Channel marker 34 - Heading back towards Stockton, Windmill Cove is just past marker 34. It's exactly halfway between marker 34 and 36.
Hope this helps. I PMed you my number in case you have any more questions.
