Pressure testing innercoolers
Page 1 of 2 12 LastLast
Results 1 to 14 of 27
    Douglas, MA
    Default Pressure testing innercoolers
    Is this something you do yourself, or bring to a shop?
    Placentia, CA
    I do it myself. What type do you have?
    steveo143 AKA DiMarco 21 II
    RIP Davey B and Denis
    LaGrange GA
    Cut a motorcycle innertube in half and attach the two ends to the intercooler. Fill up with air and squirt it down with soapy water just like checking a tire.
    Or you could just fill it up with gas and look for moisture. That will also clean out any oily residue that might have set up shop in there.
    Placentia, CA
    I make a plate with a valve stem it in and bolt it on, air it up, put it in the spa! Lee intercoolers give the best show, tiny bubbles to a full on showerhead!
    Why can't you simply plug one side, install a shrader valve in the other and pressurize it with a hand pump?
    Home Depot sells a gas line tester with a gauge and everything, with 3/4 pipe thread ready to go for a few bucks/
    Cut an inner tube in half and do what?
    I heard cavemen do this type of thing all the time with no outside assistance.
    LINK:GN-RACING.COM
    Placentia, CA
    The Harrison from the Banks, PFM, RaceArrow are only open on one end and need a plate bolted on. The Lees get a plug on one end and a plate on the other. These are Turbo type cores. A blower core would be much easier like you said!
    Quote Originally Posted by steveo143 View Post
    It still has a hose connection in and one out. Unless you needed to SEE the leak, and need it apart, can't see why testing it would be any differently. Test it the way it sits on the engine. If it leaks, I don't much care where, its scrape to me.
    LINK:GN-RACING.COM
    Douglas, MA
    What kind of pressure do you bring them up to?
    Placentia, CA
    40 lbs.
    Placentia, CA
    The Harrisons can quite often be fixed. The Lee's are trash. I always test them out of the case, I want to SEE the leaks. I just leak tested my brand new anodised Lee replacement cores made by someone else! I trust no one!
    Rockford, Michigan
    I've got the same rig I pressure test everything from the engine block, intercoolers, oil cooler, and wastegates with.
    An air line fitting, ball valve, pressure regulator with a gauge, and a line to one side of what you want to test.
    Plug the other end of what your testing and put the pressure to it.
    Close the ball valve and watch the gauge.
    Piece of cake.
    For EVERY quick jet, there is a faster v-drive somewhere.
  13. #12
    Douglas, MA
    Piece of cake.
    can you snap a picture of this? It sounds like just what I need.
  14. #13
    Placentia, CA
    T B, what type cores are you wanting to test?
  15. #14
    Registered Parker Allstar SFV2RVR's Avatar
    SFV/PARKER
    I took my Harrison cores to Carson before I dyno'd my motor and he charged me $40. He has a plate that he bolts up to them, and it's plumbed with a gate valve and a psi gauge.
