If I am right, and I think I might be for the very first time in my life, let it serve as a lesson to everybody.
The fact that you are reading the pressure where you are is somewhere between useless, and almost useless.
gn, your just trying to make me feel bad
NOW, it you said you were reading it BEFORE the filter, and in tha main gallery, that whould mean something. Your current arrangement tells you almost nothing.
True enough, the mechanical gauge is on the Accusump, it needs filtered oil. I will get a pressure reading just out of the pump, good point.
Its not the pump efficiency because it has decent pressure at idle. Leaking sloopy pumps tend to have low pressure at low Rs. Same with hi po pumps with anti cavitation grooves. Its simply a indication of internal pump leakage.
It is a hi po pump with grooves and clearances set.
Its not the block, and I doubt its the clearance, nor the oil viscosity for the same reason. But it does sound alot like a volume issue. Since this is not Sleeper CP's deal, I will guess the volume problem lies in the filter. Possibly the lines size to the remote, but am assuming thats the same as before also.
All are the same.
So, any chance this thing is equiped with some short ass 4" long POS Fram PH 30 with no bypass, and no bypass in the block because someone thought it was cool to remove it.
K&N HP-3002, also same as before. When cut apart, looks good inside.
think there is any possibility that you could be choking the engine for oil at higher RPM because the filter just flat ass can't move that much oil. Sure, at an idle it flow fine? But ask it to flow 3 times that much and it becomes a road block.
The odd part is that it flows (has good pressure anyway) with cold oil but not hot.
What filter are you running. Are you running a block mounted bypass?
