I could use some icl advice for a 540 street strip engine i'm buliding it is 10.8 compression, afr 315 heads, the cam is a Lunati Voodoo sold roller with 255* 263* at .050 with .680 lift and on a 110 lobe seperation angle, the cam card calls for the icl to be set at 104 but that would be 6* advance which just seems like a lot to me but I live at 5500 feet so maybe a little extra advance is better, I've call Lunati and one guy said to go 106 or 108 and another guy said to stay with the 104 so any help from you cam gurus would be great
Thnks John
LinkBack URL
About LinkBacks
, from an idle.
.... 255 @ .050 WILL pull to 7500RPM.... in a small block... JMO...
