Fuel Filters?
Page 1 of 2 12 LastLast
Results 1 to 14 of 16
Fuel Filters?
    Redding, CA
    Default Fuel Filters?
    I have a canister filter/ separator before my Holley blue pump.
    What micron size/ Material/ PSI should I be looking for in an in-line filter for after the pump?
    (8 AN line between the Pump and reg.)
    Tommy
    Quote Originally Posted by ram78d10 View Post
    I've talked with numerous teachers
    all the teachers I have talked to agree
    That's their problem, they can't print money.
    Quote Originally Posted by cvxjet View Post
    I rarely meet people that are smarter than me-
    Senior Member nick's Avatar
    La Habra & Water Wheel Resort
    If its a spin in type filter then I highly suggest a Baldwin. I have been using one for a couple years now and have no issues. Part number BF891, I get them at granger for like $12
    Redding, CA
    Thanks guys,
    What about after the pump? On the pressure side?
    Tommy
    gn7 is online now
    You only have to filter it once if you filter it right. Whats the sceond filter going to filter? Broken pump pieces, or the rubber from your deteriorating fuel lines?
    LINK:GN-RACING.COM
    Okmulgee Okla.
    This is the filter I use, 5 micron at 300 GPH flow and complements the looks of the fuel system as well.
    well the block is GM any ways
    IS UNDER FIRE
    Apr 2010
    Rocklin, Calif.
    I run the Aeromotive like the Earls..but it has a fuel shut-off , when you need to clean it
    Nov 2009
    LOL I almost spit coffee on that one!
    Hummmmmmmm
    wonder if he ever worn two rubbers ?
    S CP
    Tri-Cities, TN
    Quote Originally Posted by Wild Hair View Post
    yes Rick has got a nice product.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Redding, CA
    You guys are freakin halariois.
    I have always just ran one before the pump also.
    Had an Aeromotive on the hydro and a canister on the Miller.
    I was thinking of upgrading the Miller and was looking at fuel systems diagrams at different sites and noticed that some showed 2 filters.
    A 100 micron before the pump and usually a 10 micron after.
    Just curious why, and if any of you ran 2.
    How fine a filter is really needed with gas and carburetors?
    BTW Bob, I have all new line!!
    Tommy
  13. #12
    Hudson, Wisconsin
    I'd be more concerned about the water seperating function than what size micron it filters. Thus, an upright cannister style is better IMO. Jocko
  14. #13
    Senior Member rampgirlll's Avatar
    Jun 2010
    Ft Worth
    Only one. But if your running alcohol always make sure you have a screen in your funnel. Last year ran into a problem with finding lint in a barrel of fuel. After asking around and doing some research, found that alcohol is a by-product of drycleaning. If you run alcohol and rarely open your fuel filter, be sure and check it every now and then. Ours looked like my dryer screen after doing a load or two of blue jeans.
    Wwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eee
  15. #14
    Chico, Ca
    fuel injection MUST run 2 filters. A pre pump filter (typically 100 micron) then a post pump filter (typically 10 micron). but you guys with toilet bowls for fuel supply just need something good enough to filter what could get stuck in the needle and seats. However if you run an electric pump i'd think about 2 filters simply because you want something filtering before the pump, but if you go with too fine of a filter you may have a hard time drawing fuel, so a pre and post may be a good idea. mechanical pumps are a different story.
    AP
