Fuel Filter help needed
Results 1 to 6 of 6
    waterloo
    Default Fuel Filter help needed
    Been busy working on stuff.
    I am looking for a fuel filter to put on the inlet side of my fuel pump (for the dyno). The pump is a Magnaflow 500 with -12 inlet and outlet.
    I would like a filter with a SS element. No paper. Methanol compatable. -12 inlet and outlet or 3/4" pipe in and out. Any suggestions?
    So, now for other suggestions. This thing has the magnaflow pump with a high pressure bypass. Then through the flow meters which have 3/8" line in and out. Then up to "tray" outlets. So obviously needs a regulator. If I run high pressure (20 psi ish) up to the regulator (after meters) I should be ok on fuel flow on everything but big alky motors?
    Wags
    gn7 is online now
    DUH!
    waterloo
    DUH!
    PERFECT! Especially if that -12 fitting comes out and I can throw an o-ring on the fitting and screw it directly on the inlet of the pump. Should I forward my shipping address???
    Wags
    gn7 is online now
    Yes you could remove the fitting and go o-ring AN to o-ring AN.
    You want me to foward your address to?:
    LINK Fuel filter
    This one is for sale on Ebay. It has -10 fittings in it, but the filter is tapped for -12s
    LINK: E Bay Hilborn F500-2A filter
    This what the filter looks like with the fittings removed.
    Magnafuel makes a nice fitting like what your looking for with radius entry and exit. This a -10 but they make a -12, part # MP-3010
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    System 1 part #202-202412? Might work
    waterloo
    WTF did the ebay guy do to it? Sort of polish it? LOL
    Smokin deal, though.
    I may own it. If not another ebay guy has a 1200 hilborn or something. Looks decent too. 100 bucks.
    Wags
