whats up fellas. im really thinking about changing a few parts myself before i take my boat back down to elsinore for its final touches. i gotta change the mechanical fuel pump (looks kind of easy), install the oil pressure sending unit (looks real easy), and replace the oil filter (real easy), and add some new royal purple. any tips on replacing these parts? the right way to do it or should i just wait? i have the fuel pressure regulator to install also. i'll be sure to post some pics as the build goes on
LinkBack URL
About LinkBacks
Exactly.....when you do this, pull the rod out and coat half of it's length with some sticky axle grease. Just a thin coating. This will keep the rod from sliding back down before you get the fuel pump arm in position. Jocko
