how much hp
Page 1 of 2 12 LastLast
Results 1 to 14 of 19
how much hp
    Senior Member lupo1904's Avatar
    Feb 2011
    Default how much hp
    How much hp have been seen in a pump gas 468 bbc?
    750 is a walk in the park. If you consider E85 as pump, then I would say 1000 is doable.
    LINK:GN-RACING.COM
    Senior Member bp298's Avatar
    LHC
    mebbe with 2 hemerhoids blowin through a carb...
    I didn't see a
    N/A in the question.
    Hey, I am rules reader. You don't want to see a huffer, you better say something, cuz I have no plans on asking
    LINK:GN-RACING.COM
    Default Pro Stock 500 ci motors
    1500 hp
    Quote Originally Posted by 22HotKt View Post
    1500 hp
    Quote Originally Posted by lupo1904 View Post
    OK, now I may be a smart ass, but I am smart enough to know you are not going to run a NHRA PRO Stock motor on pump gas. And at the level, 32 cubic inches is a ton.
    LINK:GN-RACING.COM
    Foxwell Motorsports
    N/E Tennessee
    1500 hp
    LOL...joke, right?
    Tempe/Big River
    sounds like the keyword is pump gas. id say 700 range
    Mar 2010
    Clarksville, TN
    My old 468 had alittle compression in it with some closed chambered iron heads and a tunnel ram with 2 750s solid roller around 680 lift and it might have made 525
    Lupo don't you have a fresh pump?? What's it spinning the impeller?? Charts are pretty accurate
    WFLC
    Feb 2011
    Ya fresh pump and i have told people what im spinning this aggressor B impeller and they say its not right 6100 rpm
    Feb 2011
    Just checked the berk chart and it says im making 600 hp, but before i had the pump done i had an Alumimnum A and turned 6200, must have been really loose in there
  13. #12
    Foxwell Motorsports
    N/E Tennessee
    Describe your build as best you can. IMO a good running pump gas 467 with a TR and solid roller should be able to make 700hp. That's right at 1.5 hp/ci. You could do that with an oval port head flowing in the 325-330 cfm range.
  14. #13
    Feb 2011
    Bbc 468 dart pro1 325 no porting,mechanical roller cam, tunnel ram duel 750's roller rockers, stud girdles, msd ignition.
  15. #14
    Feb 2011
    I dont know what pistons or crank, or exact compression but the guy i bought it from said pump gas
