Dual purge valves at solenoids on fogger...or a single at Y-Block 18" from solenoids?
Results 1 to 2 of 2
    Senior Member 18GullwingMailman's Avatar
    Dec 2010
    Conway, AR
    Default Dual purge valves at solenoids on fogger...or a single at Y-Block 18" from solenoids?
    I have a single purge valve I used on my previous plate systems; will it be sufficient just before the Y block pictured or do I need to purchase an additional purge valve and run each immediately before each solenoid?
    Thanks!
    John
Name:	y block to solenoids.jpg
    That mile long and extremely high rooster tail is called a "sorry I spanked you and your outboard, let me wash your boat for forgiveness"...
    WFL Crew
    Senior Member Red Rocket's Avatar
    winchester, ca
    I have drilled and tapped the Y itself on the flat face and put the purge solenoid right there.
