Ray, I only read 1 way to adjust lash, not 6. There were different "order" but the SAME METHOD. EO-IC. RG said follow the firing order. What she didn't say was follow the fiiring order at TDC, and adjust the valves for that cylinder. Following the firing order is not the same as the TDC method.
You have posted that method more time than I care to remember. You are the ONLY person I know if that even considers that method on a perofomance camshaft.
You can't use that method on stock Z/28 chevy let alone a 310o cam ground on 106o
It DOES NOT WORK on all cams. Do you recommend 3/4 reach plugs for ALL chevys? It could possibly cause any less damage
You adjust the valves on a 1969 Z/28 just once, and you learn to stop using a method that only worked on flatheads, and should have been abandoned with the invention of the rocker arm.
LINK; Valve lash 30-30 Duntov
LinkBack URL
About LinkBacks
, from an idle.
