Engine Crank Stroke??? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 15 to 28 of 38
  1. #15
    Senior Member rocket98's Avatar
    Sandia Park, New Mexico
    Quote Originally Posted by Spudpilot View Post
    Find someone who has a P&G that can pump the motor for cubic inches.........like at a sanctioned race or some who may be involved with such things!!!!!!
    They have been beating P&G for a lifetime. I don't think this works for a stroker
    Want to thank those and you for your years of knowledge. "Books are the basis, words of experience are the tools".
    Quote Originally Posted by rocket98 View Post
    they haven't been beating the P&G, they ahave been beating the dipshit holding the P&G.
    LINK:GN-RACING.COM
  4. #17
    I have always heard this was true.....But I have never had enough money to throw away to find out
  5. #18
    I can cheat one 6 ways from Sunday. Which means you need to come up with a 7th if I am checking your deal. Rule #1, from the second you tell them which cylinderS that you want to test, never take your eyes off the guy getting it ready.
    LINK:GN-RACING.COM
  6. #19
    Senior Member bp298's Avatar
    LHC
    or, the dipshit holding the p&g tells you a 499" engine is 549, so pull the head off... and then you pull the head, and the dipshit doesn't know how to measure and calculate ci... so the dipshit calls 2 more "tech" dipshits over, and between the 3 stooges, none of 'em know how to measure and calculate ci... so while you're waiting to toss this pile of parts back together so you can get on the road, you conduct a short math class. (can you measure the bore??? pulls out tape measure. can you measure the stroke. same tape measure)...
    the moral is, if your gonna set a record, make sure you got tools to tear your engine down, and go find the 3 stooges early, so you can get the thing back together and on the road before dark. and make sure you smile while they're sticking that p&g meter up your azz...
  7. #20
    Quote Originally Posted by 2002CP19 View Post
    use something like a pencil. Take out the plug. Rotate to BDC, locate an index point (top of threads) make a mark. Rotate to TDC make another mark and measure. Stroke x bore x 8=CID
    sounds like a lot of "dipshits" were involved.
    You should have told one of the dipshits, I guessing the one that measured it, that you want to use 2002CP's calculation method on it.
    LINK:GN-RACING.COM
  8. #21
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Guess I had that coming..
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
  9. #22
    Ah jet messin with ya
    LINK:GN-RACING.COM
  10. #23
  11. #24
    well that could work in a pinch a plus/minus an inch on the stroke
    you never know someone should try it.
    S CP
  12. #25
    S CP
    Nope.
    Weight the engine, put the piston at BTC, fill the cylinder with water. Weight the engine again.
    Subtract 118 cc of water for the combustion chamber, = 118 grams
    540CID = 1106.1268247 grams of water/8=138.2658530875 grams per cylinder.
    Dead nuts accurate! Plus or minus a head gasket and deck height
    LINK:GN-RACING.COM
  13. #26
    Senior Member Flat BROKE 612's Avatar
    Feb 2010
    Niagara on The Lake Ontario Canada
    If you love someone set them free, If they come back with the cops...RUN!!!
  14. #27
    The plug hole/threads will not be square with the top of the piston. It would never be a true 90. It was just a thought...
  15. #28
    LHC
    it wasn't a terribly fun weekend, although learning did take place. the thing is, people apply for these positions. they aren't drug off the street to do it. this guy very arrogantly and condescendingly "ordered" me to pull the head - it was not pleasant. the owner just kind of shrugged his shoulders. because if you are running a class with engine restrictions, set a record and then refuse, you are in even deeper shit. and i know you're just giving the guy crap, but seeing bore x stroke x 8.... just amazing.
