Engine Crank Stroke???
Page 1 of 3 123 LastLast
Results 1 to 14 of 38
    Member Mach80's Avatar
    Phoenix, Az
    Default Engine Crank Stroke???
    I'm trying to determine what stroke crank is in my boat. Does anyone have a way to measure stroke or Cubic inches without removing a head? The engine is installed in the boat but I'm not sure if it is a 509 or a 540.
    Thanks.
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Quote Originally Posted by Mach80 View Post
    Thanks.
    use something like a pencil. Take out the plug. Rotate to BDC, locate an index point (top of threads) make a mark. Rotate to TDC make another mark and measure. Stroke x bore x 8=CID
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Senior Member Flat BROKE 612's Avatar
    Feb 2010
    Niagara on The Lake Ontario Canada
    Quote Originally Posted by 2002CP19 View Post
    1/2bore x 1/2 bore x pi x stroke x #cyls
    If you love someone set them free, If they come back with the cops...RUN!!!
    gn7 is online now
    Quote Originally Posted by Flat BROKE 612 View Post
    bore X bore X .7854 X Stroke X #cylinders
    LINK:GN-RACING.COM
    gn7 is online now
    So, you have a magic pencil that can make the turn and drop straight down the cylinder for this high tech method?
    Why did people spend 1500.00 plus for a CID tester when you can do it with a pencil?
    stock 454 bore/stroke
    4.00(stroke) X 4.250(bore) X 8= 136
    I what you checking my engine size at the races
    LINK:GN-RACING.COM
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Bob, Wouldn't the correct tool for a mechanic to use in this procedure be a ....... "mechanical" pencil?
    I didnt say it was high tech. Just a thought...
    I've been wrong before.
    gn7 is online now
    OH, I thought you had personal experience with that method
    Quote Originally Posted by Franger View Post
    I perfer to use a Camodian Magic Wand myself.
    LINK:GN-RACING.COM
    Feb 2010
    Ya but mine has PI!!! MMMMM pie.......
    Nov 2009
    Jerome, Idaho
    Find someone who has a P&G that can pump the motor for cubic inches.........like at a sanctioned race or some who may be involved with such things!!!!!!
    Well I have used that method before, just not to measure.
    Looks like the cambodian unit will do the trick...
  13. #12
    Senior Member bp298's Avatar
    LHC
    only if it's a "union" mechanic.
    radius (1/2 bore diameter) squared x 3.1415927 x height(stroke) x 8
    or, pi x r2 x stroke x 8
    with a p&g meter, if you get really really lucky, somebody might get within 10% of the actual ci with it. POS...
  14. #13
    gn7 is online now
    You guys sure do like you PI. MMMMMmmmmmmm pie!
    LINK:GN-RACING.COM
  15. #14
    Nov 2008
    Orangevale CA
    Pie is always Good , Bob ,,, Apple , Berry , Peach , Cherry , HAIR , (lol) ....... MMMMMMMMMMM PIE ...
    [QUOTE=J Shelfo; My all time favorite quote; Flatbottoms are like shopping carts, every once in a while, you get a good one.....
