Is there a way to set up a header evac without welding bugs in the collectors? My headers have been recently coated and really don't want to go welding on them. So I was thinking maybe somehow to use a pipe nipple and a nut inside the collector? Any thoughts?
LinkBack URL
About LinkBacks
...much easier & no drilling the headers!...just sayin' my .02 cents
...i had a similair problem on my B/FD (sm blk) turning 9k...it would fill the puke tank (1 qt) 1/2 full on every pass...the crank spins so fast at high rpm's that the oil climbs the side of the pan & goes out the breathers or hoses...i solved the problem by makeing a plate (1/8" alum) the length & width of the pan so the oil wouldnt get passed the spinning crank as much & up to the breathers/hoses..solved the problem
