Re rigging the boats, big Verdo goes to houseboat, new 300xs goes to 22 Daytona, WarCanoe gets bottom of hull blueprint and a Hydrive full hydraulic steering system
I thought I might let GN-7 use the Daytona as a film boat for the GN class
Just a update, Installed and rigged houseboat added 4 Ft to the rear for protection of the motor and bulit a enclosed dog house over the 275 Merc Verado with table over it house boat now 16x 60 ft 2 story
will relaunch Aug 5th bottom sand blasted and recoated bottom of hull
22 Daytona ,installed Mercury 300Xs motor, waiting on a few last rigging parts, put boat on 400# diet
should run next week
Blue printed the bottom of the !9 Cougar hull (War Canoe) and modified the center pad for the
The Parker 300, the rules make you run the gear case level to the bottom of the pad
picked up 9 mph now runs 105 level to the bottom, should run 112-113 lifted 1 3/8 " above
Going for the overall win this year at Parker !!! Picking up the Mercury Verado power system from the dealer today
Spoke with the Head of Mercury racing at Desert Storm. He did the supercharged Verado and the Quad cam 1350 motor about water injestion trouble at high speed on the 300xs. Motor has rear air entry
and at high speed water can be sucked up in the motor. The Church was sent the first 2 prototype engine cowls for real world performance testing will run the Skater w/twins and use one stock and one modified
from side to side and check for water injestion and performance gain or losses
Outboard-speak???
Qsc;wkjerbgt;q/jrlawnmowerwbvc;.qkwje cnbljierv;ijwqlawnmower erc ;irf;jh3;jh13v. c13v13rf 13; cv 1c;lawnmower 13ijbf;woehc[p982y4;/1j3 fvbc.whjigpq34.
wecli1weedwhackeruvwhecr. O bqw;rjiv 1re c;1whric 1;3kjhr vb;i13uweedwhacker rbv;3buvr;iubc1pl3iubrcv;123i ;lji3bec1 313c twostroke13r;p31r 1;3riu1b3fp;er
1clh13c cb 13c;3rpuygfp[34f4tweedwhacker b[980b4wtp83469wr'tou rgn ;o4itvbn;2'4iuo9bhv24 v 4vgb;24 24 24;iuob24tg 24t;24./.lawnmower.
LMAOROTF
Steelcomp.
If I didn't have to run a stock power head It would be on your bench waiting for your creative hands to do your magic to the block and pistons
Your talent transends the language barrier
My God be with you
You are always welcome in the Outboard Church
I can it now....steelcomp scratching his head staring at a 2smoke cylinder head..."well there's yer problem....where's the goddam valves?....Whaddya mean port the block"...
Get back to me when you can remember Bridgestone motorcycles and rotory valves.
I first glance I almost mistook you previous post as 4 cylinder rice burner speak. Very similar, but the Rs sound like Ls, and less mention of lawmmowers and weedwackers. But very similar.![]()
You mean like when you brag about being the neighborhood 2 stroke porter PRIOR to reed valves.
By the way youngster, I was running crankcase mounted carbs with reed valves on McCulloch engines when you were still making a mess in you diapers.
Suzuki tried to sell this as some NEW idea.
Yeah, it was new.........20 years earlier.
