Fuel pressure setting
Results 1 to 6 of 6
    Member 69 wriedt flattie's Avatar
    Aug 2011
    central Cali
    Default Fuel pressure setting
    Ok I am running a BBC 427 with a 6-71 blower, and 2 750 CFM Holley carbs. The boat has never had a fuel pressure guage since i've had it, so I installed a liquid filled holley guage. At idle,( 1100 RPM) it reads 6 psi. Can someone tell me what it should be. i have been told between 7-9 psi is good. Just need some advice before i tweek it. thanks,
    Okmulgee Okla.
    I have mine set at 8 psi, also running an 871 and two 750s. My system is set up on a loop instead of a return line, it loops through an enderal bypass regulator and back into the the flow, down stream of the pump. Gives me plenty of volume and steady pressure.
    well the block is GM any ways
    IS UNDER FIRE
    Aug 2011
    central Cali
    ok cool, i dont have a return line. will that matter?
    Aug 2011
    central Cali
    well anyways i bumped it up to 8psi seems to idle smoother and surge a little less.
    Okmulgee Okla.
    Quote Originally Posted by 69 wriedt flattie View Post
    I would keep an eye on the pressure at WOT if it drops I would look into at least a loop. It is easier on the pump also.
    IS UNDER FIRE
    Aug 2011
    central Cali
    ok will do, thanks!
