I pulled the V/C to loosen rockers for a timing gear change and noticed this . The roller tip chewed into the rocker body and left this odd pattern on the valve stem . Is the bow tie pattern OK ? or should they be straight ?Unfortunatly I didnt check lash prior to pulling rocker .
LinkBack URL
About LinkBacks
