Mallory Dual Point Dizzy.......Use it or re-sell it?
Results 1 to 13 of 13
    Senior Member CampbellCarl's Avatar
    Whittier, CA & Katherine Landing
    Default Mallory Dual Point Dizzy.......Use it or re-sell it?
    Putting together a SBC for a flatty that MIGHT end up in SE class. Mouzer had this thing sitting so I bought it without opening the cap. Model # is YS624MV2. Use it or loose it?
    CC
    Originally Posted by Rattle Can Lou
    Again, if I came across as a v-drive snob..I apologize,
    Mike
    Quote Originally Posted by CampbellCarl View Post
    CC
    Doesn't the SE class specify an HEI ignition? Even if they don't, why would you want to run points now days?
    Dunno about the class spec, I'll look into that part. The second question is that I'm a cheap-ass! I was picking up a cheap-cheap Casale and saw it on the bench, complete with cap and wires for $40 bucks, is it not worth the time and $ to make it work?
    Carl
    Mike
    Junior Member kylerzf3's Avatar
    Jul 2011
    jerseyville il
    I had a mallory dual point n my 72 nova with a nasty 355 n high school I absolutely loved it. Took out an Excel bluprinted dist. W supercoil,the mallory is twice as hot it'll light ur ass up u get ahold of a wire. I was running a mallory voltmaster 2 coil and u have to run a ballast resister. Would definatly recommend it over hei.
    Gone in a Flash! Speed of Heat's Avatar
    Lake Pend Oreille, Idaho
    A possible sugestion-convert the dizzy over to a Pertronics Ignitor III . It has an adjustable rev-limiter and it all fits under the cap. Less to get wet when you get hosed down! I believe the HEI is inductive and so is the Pertronics? Correct me if I'm incorrect..........
    Remember that the Ark was built by amateurs and the Titanic was built by professionals.
    Carl
    Carl, you could convert it with a module, as suggested, but first I would check the rules. Points are old school, I ran them in high school too, but that was 40 years ago.
    The rules for the SE class are stock GM points or HEI ignition. You can have a aftermarket module, and coil in the HEI, but it has to look stock. Basically the same rule as the SS.
    LINK:GN-RACING.COM
    Foxwell Motorsports
    N/E Tennessee
    I had too many Mallory dual points come apart to ever use another one.
    JMO
    Newbury Park, Ca/Bullhead City Az
    Default GM points..
    Carl, I have a couple of GM point type distributors if you need one.. I also have a remote coil HEI..(small cap)... I seem to remember there were GM dual point distributors back in the 60s..Wonder if there are any of them still around.....
    Ray
    LOUD BOATS SAVE LIVES
    3 OPEN flatbottom APBA seasons left.....Let's RACE
    HONK if you voted for obama........
    It's that button in the middle of the steering wheel........
    Douglas, MA
    Don't people use these as triggers for MSD's?
    Ray
    Yeah Ray, GM sold a few MILLION cars with dual points dizzys. There are FEW around Probably because nobody but a restorer wants one.
    LINK:GN-RACING.COM
  13. #12
    The Right Coast/SE-PA
    As far as "reliability"...12 years my Mallory Dual Point NEVER let me down...EVER!
    Set it once a year and it was good to go.
    Two years ago I installed a MSD RTR dizzy, but the Mallory is on my boat ready to drop in > when the MSD fails.
    My MSD has a looooog way to go before it earns the reliability my Mallory has.
    When properly set-up > and there is a 'proper' way to set them up they work just fine.
    My $$$ MSD really added NOTHING performance wise, vs the Mallory Dual Point it replaced. Idles the same, plugs are no cleaner. The dual point makes for a little longer duration spark. I believe the MSD-RTR makes multiple sparks before a certain rpm.
    Note > not all Mallory Dual points can use a drop-in module > my Mallory YL couldn't.
  14. #13
    Senior Member lilrick's Avatar
    Lakewood
    CC
    carl, I have a good factory electronic ignition that came off a boat I recently purchased. It has the external coil deal. It's what they used after the big cap HEI. And guess what? It's free !!!!!!!!!!!!!!!!!!!!!!!
