Cermachrome
Results 1 to 13 of 13
Cermachrome
    Cantard 71hallett's Avatar
    snow bank
    Default Cermachrome
    Anybody ever done a block?
    I hope you're considering a sunglass's and possibly a sunscreen mod with that upgrade. I've always wanted to go into the dmv, and when the asked what the main color of the boat was just say "chrome".
    Gone in a Flash! Speed of Heat's Avatar
    Lake Pend Oreille, Idaho
    If you are talking about the original cerramichrome used in aircraft cylinders, its not used any longer do to problems with high wear rates. I found it to work ok on the smaller air cooled N/A Lycomings, but any of the high HP turbo motors cylinder walls just flat wore out in a few hundred hours. The newer Nickle Chrome process is suppose to work better, but I only use old school channel chrome. You have to be very aggressive in breaking the cylinders in during the first 40-60 hrs of run time, but then they wear like hardened tool steel. Last forever and don't rust, which is great for seaplanes that sit in the marine environment. Another problem with the induced carbide type cylinder process, is that once its had a set of rings run on the surface, you can't just do a quick hone to break the glaze and run a new set of rings. You have to start all over again with a new plated cylinder. Old hard chrome will tolerate this. If for some reason I was entertaining the idea of chroming a boat engine block, I would not use anything but hard channel chrome. There are only a very few shops that know how to do this correctly. Its a lost art. To get the correct amount of oiling channels in the surface requires just the rite amount of reversing the current during the plating process. Probably one of the best shops is Harrison's in La Port Indiana.
    Remember that the Ark was built by amateurs and the Titanic was built by professionals.
    As far as chrome goes ,I thought chrome weakened the metal, something like hydrogen embrittlement?(sp?)
    snow bank
    I was more thinkin the outside of the block....like headers......any reason this cant be done.....dont know much about it.
    saw a 55 chevy at a street rod event in daytona, fla last year that had a big block chevy completely cromed. i am still lusting. that engined was beautiful could not tell where one part started and the other ended, said he drove it "regularly" and had not had any problems of it flaking or peelingmy dream when i win the lottery is to have an all aluminum bbc completely polished for my boat.
    UMPBA.ORG sleekcrafter's Avatar
    Some of the 5.0/4.6 mustang guys are coating their cylinder heads, inside and out.
    snow bank
    How hot do they need to heat the parts before they cermacrome them...heard like 1700deg could be way wrong...
    snow bank
    ....gota approach the mini skirts from all angles.
    !%@#$ Racer52's Avatar
    Stockton, CA
    400-600 degrees. for an extended perios of time (couple hours)
    I just looked into it for my new engine build. But I had already had the boring done.
    The powdercoater felt it could distort slighlty. If the block has not been bored/finish honed yet you should be in business.
    Looks almost like chrome too, and very durable.
    Racer
    snow bank
    Quote Originally Posted by Racer52 View Post
    Racer
    Thanks guys...I was worried about core shift exc.....guess I will give it a go.
  13. #12
    You will have to tell them what you don't want coated, such as lifter/cylinder bores, cam bearing, main bearing bores, oil filter/oil galley's.
  14. #13
    snow bank
    Good point...think I will bolt parts to it and scribe the lines for them to go to.
