Main bearing clearance...how should I adjust?
Page 1 of 3 123 LastLast
Results 1 to 14 of 33
    The Right Coast/SE-PA
    Question Main bearing clearance...how should I adjust?
    Clevite P bearings in mains
    1) .0029
    2) .0025 (sand the back of the shell a smidgen) ?
    3) .0035 (x-bearing or run it)?
    4) .003 (run it)
    5) .0032 (x- bearing or run it)?
    Hopefully I'll be sizing my H rod bearings tomorrow > all rod/crank journals measure the same and rod big-ends are within .0002
    Feb 2009
    Hmm to be a full thousandth off from 1 bearing to the next is kind of alot. I think you are still within factory specs though. Is it the crankshaft that is off dimensionally?
    Senior Member VAMI's Avatar
    srq,florida
    Is it to late for a line hone?Looks like the housing bores vary in size since the crank is within 2 tenths.
    srq,florida
    a X bearing will give you .001 more.a ***-1 is tighter
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    Have you measured the saddles without the bearing?
    Are you getting consistent measurements??
    It is supposed to be hard, if it wasn't hard everyone would do it. The "hard" is what makes it great. - Jimmy Dougan
    It's a celebration bitche's - Rick James
    Akita's & Boats: http://s255.photobucket.com/albums/hh149/K-Morg/
    Ok....I'm retarted....so what...
    Quote Originally Posted by Cole Man II View Post
    Tony, Tony, Tony....
    If dragboats were gay, that would make you Harvey Milk...
    Well if you want to make up a bunch of numbers to be right, then yes, that works.
    Gone
    Sparks, Nevada
    No secrets Morgan.
    Quote Originally Posted by VAMI View Post
    I thought X bearings could come either way tighter/looser
    What's a *** ?
    Quote Originally Posted by Morg View Post
    Consistent before room temperature changes (morning vs afternoon) and when I measure in the same location.
    I just bore gauged the saddles again...I know I'm fighting a tenth or two as it's cooler in my basement, then it warms up mid day.
    No bearings in and zeroing the bore gauge on #1
    1) 0
    2) .0002 tight
    3) .0004-.0005 loose
    4) .0004 loose
    5) .0002 loose
    Think I'll just run what I have vs ordering two more sets of bearings to fight a few tenths either way.
    srq,florida
    for example 743 hx means hard brg with plus .001. 743-1 .001 less clearnace my *** just was the part number.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    1) 0
    2) .0002 tight
    4) .0004 loose
    5) .0002 loose
    No expert here but shouldnt this be done by setting the mic to specific measurment (in my case 2.9375) and zeroing the dial bore from that? Seams like going off #1 is a bad idea, what if #1 is out of spec? Now your basing the others off it.
    Did you check to see if the bores are round?
  13. #12
    Thumbs up
    Shaun, you're correct...I just did the "zeroing out" for a quick comparsion.
    HOWEVER...last night I set my mic at 2.9375/6 ( middle of the spec) and had at it. I belive acceptable run is between 2.9378 - 2.9373
    1) .0002 tight
    2).0004 tight
    3) this one's fuc*ed > measuring right of the oil hole it's .0002 loose >measuring left of the oil hole it's .0005 loose!
    4) .0002 loose
    5) .0001 loose
    Hopeing I could move #1-4 main bearings around, I then miced the thickness, nope..all exact!
    If I could bring #3 oil clearance down to .0028 - .003 I be happy.
  14. #13
    Thumbs down
    Perfect circles...no
  15. #14
    1) .0002 tight
    2).0004 tight
    4) .0002 loose
    5) .0001 loose
    Seeing you posted the torque spec your builder wanted, and the torque ARP lists, you gan go up in torque on that journal, and see what that nets you...
