Timing cover Gen 6 BBC with double roller
Results 1 to 13 of 13
    Default Timing cover Gen 6 BBC with double roller
    While painting my block today I tried my stock timing cover on it.
    And guess what it fit.
    Everybody told me I would have to purchase a new cover (IMCO)
    to clear the rollmaster double roller.
    whats up with that????
    #55
    You're just special.......
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    I guess, too bad I already bought the imco... oh well I guess
    I needed some more polished aluminum on my engine.
    #55
    Just curious,, did you use a MK IV style cam and gears, or Gen 6 style cam and gears. It used to be you couldn't buy a Gen 6 style double roller chain either, but I know that is no longer the case. It would be logical to make a combination that would work with stock covers.
    Silverdale, Washington
    Talking
    Show off! Gotta admit that this Imco is purdy though.........
    the cam core is a gen 6 configuration, because I wanted to use the stock style cam retainer.
    Rollmaster is a gen 6 also.
    #55
    Ok,, I understood the cam gear and cam would have to match, it's a smaller bolt circle I think. That's probably why it would clear, without taking the time to double check a Gen 6 against MK IV style crank gear for any difference in offset.
    After hearing about all the problems with installing a mark 4 cam in a gen 6 block, I figured the gen 6 cam and retainer would be the easiest route. Plus I already
    had a new billet rollmaster set for a gen 6.
    I'm guessing if I would have used a mark 4 cam
    I would have needed the IMCO cover?
    How did you setup John's 502?
    #55
    I had the factory cam reground to suit the blower, used factory retainer plate, and a new GM single roller chain, behind the IMCO cover. I guess he got it fired but is fighting some carb problems.
    Thanks, I like my IMCO cover better anyway.
    #55
    member
    Nov 2008
    If using mark IV cam and double roller in a gen VI block you must use the IMCO or Milodons cover. The Imco cover has a large dull edged timing pointer. Does any body know of an after market pointer for the gen VI cover? SJ
  13. #12
    That my friend, would be an understatement I might as well just pour fuel down the carbs
    Quote Originally Posted by super junk View Post
    Very good question.......anybody???
  14. #13
    Senior Member widowmaker's Avatar
    San Diego, CA
    I think I had a couple of threads about this stuff when I went through it. It's a total pain in the ass. The GEN 6 cam bolt circle is a smaller diameter because of the cam retainer.
    Here is a pic of the stock gear set.
    Ignore the red circles, those were just areas I had to remove for the jesel cover.
    I ended up going with the jesel for lots of reasons already mentioned.
    Boat 405.
