What's a good set of rods for 800 to 1000hp!
Page 1 of 2 12 LastLast
Results 1 to 14 of 20
    Default What's a good set of rods for 800 to 1000hp!
    Looking to go inexpensive but still get a good rod...with good bolts!
    Quote Originally Posted by dentz72 View Post
    What length rod do you need. I have a set of 6.535" long Carrillos that I personally had magged, shot peened, and the big end resized on.
    i'm back!! 1QuickCP's Avatar
    Montana
    inexpensive + 1000 hp...aint gunna happen....try crower billet,oliver billet or carrillo this is not where u want to save the money.
    Nothing like Boost + Alcohol...................................power,it 's a drug!!
    Cali
    Quote Originally Posted by 1QuickCP View Post
    x2 lol there is a set of kryptonites for 650.00 on spam and thats cheap!
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    I think 71 Hallett told me he has a friend using Scat???? rods at 1,600 HP turbocharged with no problems. PM him if you want more info.
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    sacramento
    i just got some callies compstar h-beam rods .
    spokane, WA
    We have used stock gm rods in a small block's and big blocks making 1,000+ hp in turbo set up's......A set of eagle H-beams would be more than enough to handle 1,000 hp.
    Of course a set of olivers would be one of the best rods to choose but you can do with much less if your budget is tight.
    Travis
    Quote Originally Posted by turbo wog View Post
    Callies Compstar are perhaps the nicest of the imported rods that I have seen. They suggest the H beams up to 850 HP. Their I beam rods were rated considerably higher.
    sacramento
    this is like my 3rd set of rods, mabey they were i beam , i can't remember. go brain go .ah hell , i'm gonna look up some photos now ya got me thinkin.
    Not saying they won't work I have recently talked to Callies since they don't list any recomendations on their website. I was also confirming that they were not US made, as someone tried to tell me the other day.
    As I said, they are perhaps the nicest looking of any of the imported rods that I have held in my hands.
    sacramento
    if i knew they were import i wouldn't have bought them! i didn't buy the import crank!
  13. #12
    Ever think about why Eagle rods originally picked their name? Of course everyone now knows they are Chinese, but I am sure the orginal idea was to slide them in without too many people knowing until they were generally accepted.
  14. #13
    Member RTRIEBESS's Avatar
    Roseville, CA
    I have callies compstar H beam rods in mine they are casted over seas and finished in the usa. I would check out racingjunk.com or adperformance.com
    or highlanderacing.com all places to get good deals.
  15. #14
    I have Manley in both my BBC 1 runs 15 lbs. boost & in my other BBC 1 runs a single carb & is on the juice.I know they say their on rated for 700hp but i was told they will handle 1000 hp. someone that makes a living building engines making cams & has been doing that since the 60`s.I`ve never broke any KNOCK ON WOOD .I run the living chit out of both of them.Good luck
