How much clearance do you need between Piston and steel head for safety?
I would be more concerned about piston to valve clearance clairence!!!!![]()
.040 if using steel rods.
That is a very loaded question. Steel heads vs. Aluminum heads does not make any difference. Do you mean Steel rods? Also the make-up of the pistons makes a big difference. For instance, with cast or hyperutectic pistons you can run slightly tighter clearances due to having less piston rocking. Also, where the engine will run in the RPM range will make a difference also.
So here is the questions,
What rods does it have?
What pistons does it have? Also bore size?
What crank does it have?
How many RPM's is it going to spin?
OK guys, what else did I forget?
Paul
How much is the piston going to rock?
Are you chasing optimum quench?
QE 439 Twin Turbo
No . Problem is exhaust side of top of piston catches edge of combustion chamber in open chambered head 119 cc. So i need to die grind a little clearance in one spot on each chamber. I think Sealed Powered had these 12.5 to 1 pistons made in China. Piston to wall clearance is .005. My thought was .040 clearance minimium. Thanks for the imput. Pat
.040 could be OK, but I would shoot for .045 for that setup. If you were keeping the RPM's down around 5000-5500 I would say .040 would be fine with that piston clearance, but if you plan on running 6500 than .045 would work well and provide a good squish.
That is just my opinion though as that is what I have used successfully.
Paul
Just because you have to do a little grinding on the chamber doesn't mean the pistons were made in China. There dozens of different chambers. And when you trying to push 12.5 to 1, TRW/SpeedPro, Sealed Power, shoved that dome all the way to the edge. Some chambers just aren't "open" as others. You want to clearence issuse. Try that piston in an Edelbrock head!
LINK:GN-RACING.COM
I've had to grind out the chambers for clearance (and a little unschrouding
of the exaust valve since I was there) on a set of trw 2399 small dome
pistons! glad I check things like that, cuz you would think a trw would
be considered a replacement piston, ya know?
Be especially leary of anything that fits out of the box.
Only .001" when everyting is at max load, max rpm, max hp, max piston rock, etc.
Very helpful, huh?
Wags
(OK, steel rods, not sloppy bores, .040 min)
