BBC Rods
Results 1 to 12 of 12
BBC Rods
    Default BBC Rods
    What ya think? Is it worth it to recondition both ends, polish and shotpeen Dimple rods or just buy a set of new Eagle or Scat rods? I think for the money it cost to do, I don't have the equiptment to do the sizing, the new rods would be a better deal. Thanks for your input.
    waterloo
    Buy the scat or eagle. Loosen caps, clean threads, use moly, torque, take them to you machinist and a 12 pack and have him check them.
    They will need touch up probably.
    Still stronger than stockers. Plus, bolts 70 bucks, recon 160 bucks, shot peen ?? bucks.
    Wags
    Jan 2011
    Mickleton, New Jersey
    no doubt buy new rods chev rods arn't the way to go you won't be sorry
    You can go thru all that, hope the job gets done right, don't laugh, and end up with a USED rod about equal to the first rod, the SS. Or you can spend a little more and end up with about twice the rod. If your interested, check with Steel, I believe he has a line on these.
    LINK: Scat SS rod
    LINK: Scat PC rod
    LINK:GN-RACING.COM
    Abraham Lincoln
    Foxwell Motorsports
    N/E Tennessee
    Just went through this same thought process on a SB Ford build. Result: No way can you properly recondition a set of stock rods for less than buying a set of I beams, either Eagle or Scat. Even if you could, you still only have a 5140 rod with a through bolt, with X number of cycles on it vs. a 4340 capscrew rod that's brand new. The 4340 rods with good bolts are a lot stronger than most people realize and for less than $300 it's a no brainer.
    FOXWELL MOTORSPORTS
    STRAUB TECHNOLOGIES
    Performance Cylinder Head Specialties
    Custom Cams
    Complete Engines
    Retail/Wholesale Parts sales
    Foxwell Motorsports
    N/E Tennessee
    Wags
    Throw in a bushing for floating pins and you'd be foolish not to mag them...I don't see how a a shop can even sell rod bolts any more. WaveLocks used to be the shizz...
    FOXWELL MOTORSPORTS
    STRAUB TECHNOLOGIES
    Custom Cams
    Complete Engines
    Somewhere between Paso & L.A.
    I bought the scat pro comp's (I hate saying procomp) best 300.00 bucks you'll ever spend! can't give the dimple rods away these days!
    058 is offline
    Ford never used 5140 steel in their std. rods, All FoMoCo standard production rods were SAE 1041 mild steel.
    Foxwell Motorsports
    N/E Tennessee
    Quote Originally Posted by 058 View Post
    OP was talking about BB Chev, but you're right...I should have said "at best"...
    FOXWELL MOTORSPORTS
    STRAUB TECHNOLOGIES
    Custom Cams
    Complete Engines
    stock BBC MKIV rods are 4130, then 5140 in the GEN 6 starting with the Vortec, and now all replacements are 4340, but they aren't made here.
    LINK:GN-RACING.COM
    Abraham Lincoln
    good point GN- I just really doubt that chinese 4340 is the same aerospace grade as say what CROWER, or Carillo uses.................
  13. #12
    No, they aren't. But that "replacement 4340" rod will kick the old GM rod's ass up and down the street all day.
    You would shit if you knew how much GM pays for that rod. GM doesn't import the rod. The have a contract with a supplier here that imports them.
    LINK:GN-RACING.COM
    Abraham Lincoln
