Originally Posted by
bp298
temperature and altitude are two attributes that impact relative hp. but by themselves, it may be a little more, may be a little less than a generic "standard" of 3%. running a 60* increase by itself, you might only see 5% change in relative hp. an elevation change of 1000' might result in a bit more change, but that would depend on changes to other factors. "density altitude" is the usual method for describing conditions. it's calculated through a combination of elevation, ambient air temp, altimeter (pressure), and dew point. depending on the combination, i can show you conditions at relatively the same elevation where air temp is 75 vs 90, and the relative hp at 75* is way less than at 90*. from these 4 factors, you can determine relative humidity, absolute air pressure, relative density, etc. all of these factors are going to affect relative hp either up or down.
bracket racing, you need to have a pretty good idea how these factors affect your own relative hp, and compensate accordingly to hit the number. d/a changes affect different engines differently. there are myriad different ways people will compensate for changes.
