intake for 460 ?
Results 1 to 6 of 6
intake for 460 ?
    Oct 2011
    Default intake for 460 ?
    Building 460 bbf, stock d0ve heads, 9.5-1, cam is 224@.050 intake and 230@.050 exhaust, looking for 450-475hp. So what intake you guys thinking? Is the weiend 8021 better than the 8012???
    San Francisco Bay Area
    Cool
    Quote Originally Posted by rpm0414 View Post
    The Weiand 8012 is more than capable of supporting your hp goals and is actually better suited than the 8021 since the ports at the intake flanges of the 8012 will match the D0VE head's intake port entries.
    That being said, a 9.5:1 460 with "stock" D0VE heads and a 224@0.050" cam ain't gonna quite make 450 hp, not even with OT headers. Large-valved, well ported D0VE's, OT headers, a good distributor, and an 850 cfm carb will get you close.
    LO
    High Flow Dynamics
    This post © Copyright 2007-2012 Paul Kane. No copying, linking, printing or otherwise without express written permission.
    Oct 2011
    How much flow from the heads you thinking will generate this power. When I mean stock I'm also thinking good valves, port work, etc. Just not aftermarket heads.
    Oct 2011
    If you were building this to make 450-475hp, what combo would you run?? Thanks for all the input
    Cool
    Are you running tubular OT headers? If so, that's a big plus. If not, then you are going to need more camshaft.
    Assuming OT headers and a well-planned engine combo with only a little bit more cam (if you must have 475 hp) and you could do it with mildly ported D0VE heads that kept the stock valve sizes.
    Feel free to call for details and we can discuss; I have little time for all the back-and-forth typing but would otherwise be more than happy to help.
    High Flow Dynamics
    Senior Member sturat's Avatar
    Houston TX
    Default Listen to Paul
    Quote Originally Posted by LakesOnly View Post
    I would do as he asks.. He will tell you waqnt you need to know and will not blow smoke up your a$$ Paul knows his poop!
    Legalize the Constitution!
