Will I be OK?
Results 1 to 14 of 14
Will I be OK?
    Oct 2011
    Default Will I be OK?
    Hi guys, I am new to the forum and would like some advice.
    I just got done rebuilding my 502 from my DCB 22. Here is where it is now.
    4.503 bore
    JE - 257961 pistons
    AFR 345's
    Custom grind Comp cam
    Manley Rods.
    Just a quick rundown of what is in the motor, My big concern is my rings gaps. I talked with a few people and I went with these for ring gaps
    Top - 0.027"
    2nd - 0.024"
    My biggest question is will this be acceptable? Colling system is a raw system and the block really never gets too hot.
    I am running a B&M mega 420 @ 10psi or plan to run 10psi. Static compression is 8.7:1
    Surprise, AZ
    What type of rings are they?
    Quote Originally Posted by sultan.of.swing View Post
    4.503 bore
    JE - 257961 pistons
    AFR 345's
    Manley Rods.
    Top - 0.027"
    2nd - 0.024"
    So are you going .0060"/inch of bore on the top ring and .0055"/inch of bore on the 2nd? Is that what the sheet is telling you for a "blown gas" engine?
    The math on the 2nd ring should actually round to .025", remember, that's "suggested minimum", however many of the spec sheets are calling out for .0010"/inch of bore more on the 2nd ring now. For example, one set I currently have here is asking for .0055"/inch of bore top ring, and .0065"/inch of bore on the 2nd ring.
    If it's already together, it should run fine.
    Oct 2011
    Quote Originally Posted by 67weiman View Post
    The pro seal rings that came with the pistons,will have to look tomorrow to see if they are moly rings. I ordered the pistons since they are FI friendly.
    Your kidding me right? They are now selling rings as being FI compatible? WTF? Does the engine require special FI compliant oil and sparkplugs?
    LINK:GN-RACING.COM
    Abraham Lincoln
    Oct 2011
    So are you going .0060"/inch of bore on the top ring and .0055"/inch of bore on the 2nd? Is that what the sheet is telling you for a "blown gas" engine? The math on the 2nd ring should actually round to .025", remember, that's "suggested minimum", however many of the spec sheets are calling out for .0010"/inch of bore more on the 2nd ring now. For example, one set I currently have here is asking for .0055"/inch of bore top ring, and .0065"/inch of bore on the 2nd ring.If it's already together, it should run fine.
    The sheet called for .0060 for blown gas top and bottom but the je rep recommended the .055 on the second ring. I am concerned and wondered if I will encounter top ring flutter. I Would feel safer with 0.030 on the top ring and 0.032 on the second ring. Think I can safely get the rings back off and open them up some more? This motor needs to last a while.If 0.027 and 0.024 will work then I will leave it as is.
    Oct 2011
    I was referring to the pistons being FI friendly, not compatible.
    Castro Valley, Ca.
    Not having the correct rings could be the cause of a DNF, just sayin........
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2002 Corvette M-6 Coupe
    Remember in November
    Well done USN Seal Team 6
    wish I could blame that on the rings. That would be too easy
    LINK:GN-RACING.COM
    Abraham Lincoln
    Oct 2011
    This is the ring set that I used.
    J100F8-4500-5 Product Detail Information - JE Pistons
    Keep in mind that the suggested minimum gaps are "minimum", supposed to keep the ends from butting together. Thinking has been changing on what gaps work best, but I don't think you have to pull the pistons back out of the block for your engine to make changes.
    What is it that changed your mind about what gap you should have versus how you have them gapped?
  13. #12
    Oct 2011
    Keep in mind that the suggested minimum gaps are "minimum", supposed to keep the ends from butting together. Thinking has been changing on what gaps work best, but I don't think you have to pull the pistons back out of the block for your engine to make changes.What is it that changed your mind about what gap you should have versus how you have them gapped?
    RResearch and the fact that when i can trim the boat right I will run 115mph for several miles so the heat is another concern.Gonna be keeping a close eye on my J&S Safeguard
  14. #13
    My background goes back to building marathon ski race engines in the 90's at GT Performance, when the conventional thinking was the larger top ring gap. Based on the large number of engines assembled that way, I would have to say yours will be OK.
    However, if you need to pull it apart and open the gaps up a few thousandths to sleep better, I wouldn't talk you out of it.
  15. #14
    Oct 2011
    My background goes back to building marathon ski race engines in the 90's at GT Performance, when the conventional thinking was the larger top ring gap. Based on the large number of engines assembled that way, I would have to say yours will be OK.However, if you need to pull it apart and open the gaps up a few thousandths to sleep better, I wouldn't talk you out of it.
    I appreciate the help kind sir,it would probably be best just to open them up a bit. Gonna sleep on it for tonight.
